Doesn’t work either, used Sidebar 32-bit mode, tested WLM gadget by Cener undocked before logging in and after logging in. can’t figure it out tbh.
Also in the folder where the CenerTCPMessenger.exe is located there is a config file for it, which has a port number setting. Anybody know which port Escargot uses?
it dont works on Vista with wlm 8.5
its a txt file and not a exe file or sidebar file
:S How can i install it ?
Rename the file, removing the “.txt” and open.
So anybody figured it out how to make Cener’s WLM gadget to work for Escargot or it’s a lost cause?
Its a lost cause :S
