Share your AIM username if you're using Escargot/NINA
Hello, it is nice that you can use AIM on either the desktop or the mobile version using the Escargot/NINA private server. My username at AIM is TalalQ8. Please share your username so people can send you a friend request.
sure!
ginger3829181 and idk how to add you in aim?
Hello, the process may vary depending on the specific version of AIM in use. Adding friends on the mobile platform appears to be quite simple. Would you like me to attempt sending you a message so you can receive it on your desktop or mobile device?
Try to be online on AIM in order to send you a message.
hmm that’s weird
oh i think im going to install aim on my laptop and not vm
also
yea i added you. (i think yesterday in my country it was thundering so I couldn’t be online)
I see. Could you please try sending a message now?
yea now it works!
Add me =D sebasxdd13
Hello, I have sent you a friend request.
Username is SuperMarioWar and I am using AIM 5.9.6089 on my old Windows XP lappy?
Hello, I shall be sending you a friend request presently.
ivantimasony2008. can you add me to your contacts?
Hello, yes indeed I will be adding you to my AIM contacts.
technoplayz7450 , please add me!
