HOW MANY TIMES ARE WE SAYING.WLM 2012 WONT CONNECT.MESSENGER REVIVER IS DEAD SINCE MAY 17TH 2017.STOP SAYING YOU CAN GET WLM 2012 WORKING @PedroxTheBest !
I Get It Do Not Say: No I Can STOPPPPPP
IT WONT WORK REVIVER IS DEAD SINCE MAY 17,2017 god
Finally you realised that reviver is not working
stop is working stop F**k
I don’t know why would you even want WLM 2012. IMO it’s horrible and by that point people moved on to stuff like Facebook or Whatsapp, or used revivers to use older versions of Messenger. ![]()
its
not
working ![]()
if it is working , send a proof
Menseger-Reviver-10-6-8.zip (518.5 KB)
work with this to install only go to advanced and do a new install and start
Ah no
Look This Method (Sorry For The Language) Como Instalar o MSN 2012+MSN Plus no Windows 10 Vídeo 17-07-2016 - YouTube
it won’t work, did assholishKirk’s message not get that clear enough?
It Work
THIS IS FROM F*CKING 2016
Corpo parece pouco claro; é uma frase completa?
u can say fuck
Its from 2016
Is Work I Tested 1 Day Ago And Worked
show image proof plz and I will give you $500
lies , send proof if it works
Lmao wat
