Hello everyone, so, why am i posting this here in this interesting category? well, the reason is simple, i am making my own IRCX web only chatroom website (which is related to my project), i have already made some files and even starting to test the chatrooms, added some other cool features as well. I have decided to make my own IRCX chat because i couldn’t revive MSN chat due to the lack of design based resources, i almost gave up but then a new idea kicked in and decide to create my one instead which will have significantly better moderation, i will also include a screenshot as well, meanwhile, if you are interested, you can join our server, here is the invitation: https://discord.gg/3Sueh8bXuF
Just like to say this isnt even IRCX. As IRCX uses Internet Explorer librarys.
I think this is a bit of false advertising as you say its IRCX when its not.
Well? i ain’t using OCX, they can be tampered too easily
Right now i am reading some documentations, i will add more commands later.
You kind of need to if you want to revive IRCX.
Modern browsers doesn’t use OCX at all, i could make it http and make the code compatible for the old versions of windows, but then my website might experience some DDOS attacks and some other stuff related to it and i don’t want that to happen
so instead i will implement the commands and some other stuff, compared to MSN Chat which was a failure in the end, my one won’t screw up.
You dont know what your on about. You dont need to make it http and do you even know how DDOS attacks work? look all I have to say is your probably doing a great job on this chat project your doing but please know what your doing because I dont think you know what your on about at all.
Well, at least let me finish the development (by that i mean the html’s server codes and stuff like that), if you have any advices, then i will listen and consider them with pleasure ![]()
Well atleast I tried on my IRCX implemention in Python. shrug
Umm, you used mIRC which isn’t IRCX ![]()
OCX is basically UI related stuff, i have accessed MSN Chat’s OCX file, in it there are basically emojis, sounds and info about the OCX file itself, nothing else, therefore it’s not necessary, OCX format itself isn’t even mentioned in the IRCX documentations, just front end is enough, i will add some more commands and errors mentioned in a documentation which i am reading, and about the website itself, now i am thinking about how to store reports so that i could review them later, i have already created next pages:
1)Home page
2)Account registration
3)Chat room list (work in progress)
4)Support page (again, work in progress)
5)chat room (gotta add more commands and errors mentioned in the documentation)
6)sign in (with the “remember me” feature)
7)Account page along with the settings (work in progress)
I will create some more pages later when i will finish working on them, on top of that,14 languages will be supported.
I know but you know the python code about my IRCX
You arent using IRCX tho.
You still didn’t read my previous message properly
