someone helps me know how to log in to MSN 4.7 (by the way I already patch it)
The problem is that it does not leave me, I see an error.
What error code?
Are you from Windows XP?
try spamming enter ![]()
dunno if it works but eh
other solution?
did you mark this option while creating your account?
ββ suport for old MSN ββ
Yes
Use MSN Love! for patch⦠https://msnlove.neocities.org/
Balazs_V really wants people to use his software ![]()
Use MSN 5.1 instead.
Cause I put many Escargot functions for my program. This is MSN Love
