Problem description: Cannot login with MSN 7.0 and 7.5
Error code/error message: 81000306
What has been tried so far: I’ve tried to permit the application on firewall and to use compatibily mode but it doesn’t work
Messenger version: 7.0/7.5
Windows version:(Windows 10)
I need these particular versions because here I can have calls (At least in LAN)
are you sure you’re patched everything?
PPCB
3
calls worked for me on 7.5 ( on a same network )
Uhm… Yes. I’ve used PATCHED section to download
despite you using W10, are you sure TLS 1.1 and the rest are on? not sure if this applies to w10 but still
Problem solved… Italian version is not patched well so I’ll call an admin with a fix
