So I was trying to log into aim Phoenix whit my Phoenix username and password but I didn’t work ? What do I use to log into Phoenix AIM I’m s confused ![]()
Yeah, I would advise against any of the “Phoenix” projects. I went to its website, and saw numerous things that were flags so red, they were crimson. I would look into Escargot/NINA instead.
Phoenix Proyect is very abandoned at this point, i recommend you use AIM of escargot.
Phonix works verry well.
WARNING: I DO NOT RECOMMEND PHOENIX AIM, BECAUSE IT HAS BAD HISTORY AND OWNER.
Alternatives:
- NINA/Escargot (I’M NOT USING THAT ANYMORE, I QUIT THERE)
- NunoBox (my own service, but yh.)
- CrossTalk (Their AIM service is not complete!)
etc etc vice versa
That’s partially true (i mean the phoenix part), i have heard that their security was awful and that their code was leaked (well, something like that)
what’s the most-used and most-active alternatives to phoenix for aim?
NINA, but they have their own issues and shouldn’t be used either.
ChivaNet has an AIM service which is an instance of Open OSCAR Server, and aside from NINA/Phoenix that is the most active AIM server right now.
I’m also working on support for it on CrossTalk. ![]()
isnt nina dead? are their servers somehow still in operation???
Yeah -_-
If you check there website now. Its still alive. With the server Web for aim
Sorry for not saying anything for like a year , but ye I stopped using phoenix just because I did see any use in joining them , I’m now just looking for better alts now
