Wildman’s server got knocked out, which means no more AIM for us, until then, AIM users, go sign up for Escargot MSN, thanks. RIP AIM Phoenix 2017-2018.
this is very hard to believe , actually the server is just down
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
rrww
It’s real.
so , prove it
if the server is down the website will be also down , the same thing happens with escargot , lets just wait the server go back to normal and you will see
Not coming back, maybe next day (or in that case, never).
can you stop causing drama , it will be back , its not even the first time that this happens ( this already happened ALOT )
Yahoo is down too
Ask Wildman instead of spreading rumors mate. Sure the server timed out, but that doesn’t mean its gone.
Hard to believe he didn’t have a backup. I think he said it was a separate old Core 2 he has running. I doubt that his has VS installed on that machine…
Wildman… if you still have the code, release it.
yes like Escargot!
make it worldWide
it’s back up
Latest News 7/24/2018
- Clients 5.2 and newer can now use direct connection, however, it may only stay connected for a few moments.
- Work on supporting proper timestamps.
- Code logic optimizations.
UwU
SEE , i told you that the server was just down
