I want to install these old M&ms games i used to play back in 2006 but i can’t install them and this error message keeps coming up.
Try enabling XP or below compatibility settings, if that still doesn’t work. You may have to use a VM or Use an actual XP machine
Didn’t think about that thanks i tried running them earlier in compatibility mode under Windows XP server pack 3 but that didn’t work either i did Windows 98 and it worked just fine thanks.
3d Groove?
They are from 2002 they used to be on the M&ms website back in the day.
Oh Ok.
