Need Some Help - Recovering erased messages off of the Samsung SGH-E900
So I need some help. On my E900 were a lot of old messages, those being from family members and the now defunct Orange UK (Orange messages are on my radar for possible archival).
While clearing out some messages, I had accidentally pressed the select all button (Due to the wierd UI layout.) This resulted in the messages getting deleted. There’s a secure delete option, but that was disabled at the time. I found out that the messages still exist under the hood and can be retrieved. The only issue is that I can’t find software that can do it.
So far, the only promising thing i found are old versions of a program called “UEFD Physical Analyzer 3.9.0.” This program is a forensic level extractor, and the only issue is that this program requires a license. I do not want to risk running a cracked version. Can I have some help?
(PS: The E900 drivers don’t work on Windows 10, i can only do this on XP)
Sources:
If youre afraid of malware, run it on a VM. Easy
I can only find ones for version 7
Try going to DistroURL and/or Orgnik33 (both on Telegram) and asking them for help
