Today, I was looking through my old DVDs and within my Superman Returns DVD lay an old Orange UK (Orange UK Is no longer around) Promotion from approximately 2007. This promotion came inside of the DVD Cover. The thing I require help with is finding the game, the ringtones, and the wallpapers for archival. I considered texting 247 however i changed my mind when research on the number revealed it to apparently be a scam number now. If anyone actually has these files around, can you send me them or at least help me track them down? I have scanned the promotion below:
after some google searches, i found some shady looking website that had the superman returns java game jar file. unfortunately, it seems to be that i cant get past the train station splash. the music continues, but the game just softlocks on that point. i dont know if its the game file being corrupted, or the J2ME emulator not supporting the game, since i found more superman returns jar files and they all get stuck in the same place.
just for the sake of archival, these are all the sources i found hosting the game
https://phoneky.com/games/?id=j4j21784
https://phoneky.com/games/?id=j4j83580
http://www.andrew-lviv.net/downloads/en_games_view.php?id=14458
mobiles24’s jar files seemed to work on an emulator for me, but it was glitchy. maybe all these jar files can run on an actual old phone.
hope this helps!!
also, i found this one pretty interesting
Superman_Returns-5552.zip (136.4 KB)
Andrew LVIV has a mention of Warner Brothers and Orange SA, so that’s a good sign. I’ll do a VirusTotal Scan of all 3 you linked, and i’ll try to sideload them on my Samsung SGH-E900. I’ll update you on if they run.
This is the correct game. 2 Of them however (can’t remember which) install fine and then crash when you attempt to run them. The 3rd runs at the incorrect resolution.
hmmmm… idk then. those are all the ones i can find.
Don’t worry, it’s ok, thanks for the help
