Have you wanted an active myspace clone? check out https://www.friendproject.net/
it has daily people registering and active ppl, most of them will add you in minutes or hours and you can decorate your web as your wish!
The best part ![]()
Friend Project is better than SpaceHey but one thing SpaceHey gets right is copying the Myspace 1.0 layout which was better than the 2.0 layout which Friend Project is trying to copy. Also while Friend Project is probably the best Myspace revival out there it is not a new site and has been around since at least 2008 and it is absolutely not the same site it once was back 10 years ago and i don’t like that a bunch of TikTok teens took it over tbh.
