My radeon rx460's software
a budget gpu for all of your needs @icanttellyou
which one
the gtx 1060
ok nvidia users here’s why you should never use nvidia ;-; NVIDIA is always the reason - YouTube
that never even happens to me lol
waiting for budget rdna2
sorry but i have rtx 3060 cause i need it for my deepfake and A.I Learning AMD Does not even has A.I CORES XD
try get a gtx 1660 or otherwise 970
i really want to mess with ray tracing lol, i guess i have to wait quite a while for budget options to appear.
I wouldn’t really trust those ā€œtech youtubersā€ with circlejerk communities like bob pony and enderman.
maybe it’s smart to get a power supply first cause RTX GPU’S needs a 550 watt or even 750 watt power supply
i’m planning to get a whole new computer lol
well if you are gonna get one make sure to build your own cause it’s way cheaper
