I nothing idea why but msn escargot won’t work same after follow the tutorial… he have a message bad password or login… bit he have insert a good information… I don’t understand.
Regards
Regards
You use the pre-patched version or the unpatched?
I have pre patched version, and MSN explain "MSN Messenger could not be sign you in because the sign-name you entered does not exist or your password is incorrect.
[…] Error: 80048821"
I use:
MSN Messenger 7.5
the MSN Messenger Connection TroubleShooter explain he block at: “Key Port” after “Proxy Server” and “DNS”
Turn off your proxy. If don’t have, go to you firewall and allow MSN Messenger.
He already enable
So I do not know… It gives some problems when trying to connect in Windows XP… Try to use MSN on a PC with Windows 7 or higher.
ow :c okay I try :c
Sorry for not having help…
okay thank you, I ask with it
Please download this tool and copy paste the result: https://gitlab.com/valtron/msn-server/uploads/9251232fd45b93f381c4b521dfb5e671/Escargot-Troubleshooter-1.0.zip
