Hi !
I can’t get msn to connect anymore. First I was chatting with a friend and kept having the notification that she did not receive my messages. So I tried to disconnect from msn to log in again.
But now it’s telling me that I have the wrong username / password (error 80048821).
But I do have the good ones.
Is there something I can do to fix this ?
I’m running the prepatched version for msn 7.5 and I have Windows 10
Thanks for your help !
I don’t know if it’s related with this, but I can’t login. It’s been giving errors/spinning infinitely for more than an hour. (error 81000306 - “probably for a service or an internet connection problem” (translated))
Prepatched portable MSN 7.0 with Windows 10.
I am having the same issue on Windows 7 with MSN 7.5, both pre-patched portable version and installed version.
(The error code is the same as Leandro03’s:81000306)
i can’t login too
, say wrong password :S
Same here, not having any connection.
(Error Code: 80048821)
EDIT: It’s working for me now.
@leandro03 @Hyperuranium The only thing that comes to mind is, maybe your firewall is blocking relevant ports? (1863 is used by MSN, and 1864 is also needed for Escargot.)
I don’t think that, it always worked… sounds like it was a server problem, it’s working now.
theres a problem with escargot servers
That’s why the tool I shared (made by one great Escartgot engineer @enhanox) is great because it will tell you that quickly
Environment Information:
Windows version 6.1.7601 (Windows 7)
Client Version Information:
Version 7.5.0324 at C:\Program Files (x86)\MSN Messenger
Patch Status:
Version 7.5.0324 is patched
Ping Test:
Trying to ping Escargot:
Success Success Success Success
Connectivity OK
Escargot Connectivity Test:
Could not connect to Escargot
SSL Certificates & Protocols:
Enabled security protocols:
TLS 1.0 TLS 1.1 TLS 1.2
Flash Player Version Check:
Flash Player for Internet Explorer could not be found. Please (re)install Flash Player (ActiveX).
Misc:
MSN Messenger logging is currently DISABLED
this is the log from escargot troubleshooter
UPDATE: the problem fixed.
for the record,it was the first main black-out of Escargot
