Will there be any MSN Plus remake aswell? For the good old functions?
Thanks
-Vidar
IM: vidskater@hotmail.com on this MSN
Thanks
-Vidar
Currently no plans for it l.As for now you can use the old one that is still usable
Regards
MMIC
Can you link it as of the one i found does not work (Edited)
Update here is a link to the newest and still active MSN Plus
https://www.mediafire.com/file/u1v5uwapo99xc44/MsgPlus-4.83.374.exe/file
Uh thats Messenger Plus 4.83. the same version from the escargot website.If WLM 2009 gets supported soon then I will upload 5.02.
