I Searching “MSN Messenger For iPhone” And No Results Only Live Messenger And The App Is UnAvailable
Yeah bad news I have iPhone as well and probably it be up when messenger 2011/2012 are supported
The iOS MSN client is not supported on Escargot.
Sadly the only cracked app is 2011 and its for only 32-bit iPhones. Newer iphones wont work you will need a older 32-bit iPhone or iPad or iPod Touch
yep
only solution is make a XMPP proxy for escargot server in order to use msn on any device with xmpp client
