MSN Messenger 7.5 not logging in in Virtual Box
Problem description: When I try to log in in MSN Messenger, it shows an error.
Error code/error message: 80048820
What has been tried so far: I tried re-installing messenger like three times, downloading unpatched version and patching it manually, and disabling firewall, nothing works.
Messenger version: 7.5.0324
Windows version: Windows XP Service Pack 3 (Running In VirtualBox)
Have you considered using Legacy Update? That should help you update root certificates on Windows XP/Vista/7 and also allows you to use any version of Windows Live Messenger up to version 2009.
I don’t know what is that, Legacy Update?
It didn’t work
