This is a patched version of MSN Messenger 7.5 that runs on macOS.
- Install Wine.
- Unzip this file.
- Drag to your Applications folder.
- Launch, e.g. from Spotlight.
Notes
- This version is patched for Escargot.
- It runs successfully even under macOS High Sierra.
- While it also contains Messenger Plus! files, I could not get those to work. Any help/debug info appreciated!
- Navigating to the Options > Connection tab will cause a crash. Suggesting you don’t try.
