i used my escargot info and it did not Work, SOMEONE, Help Me?!.
Error code, HRESULT and pre-emptive:
Did you update your patch to the newest version? https://escargot.chat/patcher/ (This is required if you have never run the patcher before, because by default Escargot does not set anything to connect to)
(If using an non-Escargot patcher, ignore the above)
nvm i made it Work.
