does anyone have the msn messenger 4.6 sounds in wma format
Here is a collection of MSN Messenger 1.0-4.7 sounds. They are in the original WAV format.
Unfortunately WMA can mean several different versions of the WMA codec, so you’re probably better off encoding it yourself into the specific codec you need.
thanks
