Hello, I’m here to check if there is any version of msn for jailbroken ios my version of ios is 12.1.1 and use Unc0ver jailbreak, From already thank you very much
Hello, the iOS versions of MSN/WLM doesn’t work as of right now, so you can’t use them
Not even if I have jailbroken?
no, because the problem ins’t installing it, and yes making it connect to escargot’s servers
as of now it’s not working since it was based on WLM11/12 and escargot doesn’t support it
Oh
okey thanks for the reply
