Yeah… i know, but that necrobump…
Also MSN Explorer still exists, but you need to sign up for a service.
I’m not sure if it was possible to change the profile picture in MSN Explorer 6-7. I’m pretty sure its possible in Explorer 8. Here is my depiction of what it might’ve looked like in the login screen of Explorer 6-7
Yeah.
What OS it that om because i cant get it on windows 95 with it responding.
look at the title and then you know what os is
how
Wait… How?
I guess it is just a IE frame
welp its ez just connect to lan and youtube still supports the ie (internet explorer) version! you may also use the msn internet access iso from internet archive
I have MSN Explorer and it’s basically a MSN Premium control panel with a browser based in IE 11 and some extras, it doesn’t support full screen. Also, you can create @msn.com e-mail accounts from there. ![]()
why are you here…
why not?
ohok nvm
im 99% sure this is the most bumped thread of mg
wey yo quiero instalarlo chales
Tienes que comprar MSN Premium
lo se :c #cactus triste :v
How did you even do that? Is it an old one?
