i have never used MSN Explorer before, and unfortunately i cannot log in into the app because i guess Microsoft doesn’t support the free versions of MSN Explorer anymore. I was wondering if it would be possible to patch any version of MSN explorer to make it work on Escargot Servers just like Messenger.
what version you use
It’s not possible, since MSN Messenger and MSN Explorer uses different protocols…
And the MSN Explorer protocols are not being worked on for the moment.
@OhHelloThereImTheGuy tryed make a revival but not works
common version is usually 7x
I hit a roadblock with debugging, so I couldn’t make a “barely working” server anyway.
what versions did you try? and what roadblock did you hit?, how did you debug it?
BTW: if we have to start with something try MSN Classic on Windows 95 A, and to emulate a modem you could use Virtual Modem Emulator by FabulaTech, if you try it you will need this
-----BEGIN VIRTUALMODEM KEY BLOCK-----
X7S9mBCo82hi2w8vDy2yAVBLRgoCAAAAYEqkzitG
kulI2ywMViREfg8AN/9VtbuJhsKx4vKMFRPK6vI+
v3+oRXucAATJC5fHDwCe2yLoDtbKxRmYN+TRZZhm
0lvJeuUf2HU3qnyyxBTTdQoO+bmqcgEGHkOBbDuJ
MFQImTEMgmrv4TvvCYCcTfqRDk3QmX4jDPc7+aJp
konTEEdfMebg7FkOrhzS6lP+8EDctLtVpvurR68h
Q5tVRQge/r2UNCkMhhR5jfWn7YychyugsxyfpxF7
nj95ewq7ZvwLQhCzM3r8H5CpoMM5byZQJBTIAOah
sFLqhx0=
-----END VIRTUALMODEM KEY BLOCK-----
new link?
