MSN Content Plus Registeration Error?
How do I make this thing go away forever?
I tried uninstalling it and I did but the problem is it won’t go this warning away forever. Any help?
Uninastall messenger
That won’t do any good.
I would love to but this registeration thing will still pop up
What version are you using?
The current version of WLM. 14.0.
Use revo uninstaller to uninstall plus and reinstall
Okay?
At least in the setup version I have, that message comes from C:\Windows\msnlogm.exe.
Killing that process if it’s running and deleting/renaming the file should do the trick, or remove the msnsyslog string value at
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Run
or HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run so it doesn’t run at startup.
I did removing the msnlogm during registry editor.
and then the expired trail pop up wont leave me alone, and it’s “msnsyslog”. Whenever I delete or rename it, it respawns to normal
I see the respawning too, there’s two processes and there’s a watchdog. In the Details view in Task Manager, right-click msnlogm.exe and choose End process tree. If that doesn’t work, do the same on msnlogs.exe.
Or command line:
taskkill /f /t /im msnlogm.exe
Alternatively you could just reboot (and double-check the Startup apps in Task Manager to make sure it’s not going to startup again too).
It works! Thanks!
