Could I try out MSN 9? I know that it will crash a lot, but I would like to try it
Assuming you mean WLM 2009, there are no plans to make public betas for it mainly because the way the client is made and installed would require technical expertise to maintain and patch, so prepatched installers would be a must for that to happen, which at this point means almost wrapping up development. Also we just don’t have the resources for that yet. Maybe in the future though, we could consider it, but that’d most likely be for major core changes outside of MSN, like a distributed server architecture that we plan to support some time after WLM 2009 support is out.
Alright, thanks for telling me
