Problem description : When I open MSN 2009, it opens, stays open for a few seconds and closes.
Error code/error message : no code :')
What has been tried so far : Install Menseger Plus! 5.02
Messenger version : 2009 - escargot.chat
Windows version : Windows 10
NicoDM
January 9, 2024, 3:06am
2
Do you apparently have any Window modifier or a registry tweak?
NicoDM
January 9, 2024, 8:33pm
4
Do you apparently have the Windows Logs thing disabled or is it enabled on your computer?
NicoDM
January 9, 2024, 9:31pm
6
Well, on this case, I’ll need you to get at Event Viewer (or Visualizador de Eventos)
Then, get on the Aplicativos:
is there anything associated with Windows Live Messenger?
“há algo associado ao Windows Live Messenger?” sim, tem minha conta e o contato de minha mãe e meus amigos.
Isso, aconteceu isso
como arrumo?
consigui arrumar o msn, mas muito obrigado pela sua ajuda!
Maybe you should uninstall Messenger Plus and should fixed. I hope it’s fixed. If does not work, reinstall WLM or Add it to DEP (Data Execution Prevention)
