Problem description:I tried downloading the Messenger Plus! 5.02 and my computer is detecting it as malware
Error code/error message:Trojan:Win32/Wacatac.A!ml
What has been tried so far: I haven’t tried anything yet cause I don’t wanna screw it up.
Messenger version: Messenger Plus! 5.02
Windows version: Windows 10
Ignore it, the antivirus says that possible because it has “similar code”
is there anyway I can stop windows defender “block”, so I can use it?
TReKiE
5
In addition to turning off, you can also add exceptions to specific files or folders, or if it’s quarantined, allow the “threat” and it won’t be triggered again.
Personally I use the exceptions myself in various ways and it works well to maintain sanity.
Chaziz
6
this is due to the installer bundling some crapware (internet explorer add-on iirc) that can be easily avoided by turning off a checkmark.
thanks for the help everyone! I managed to make it work
The antivirus swears at him because he has a code like a real virus. This is not a virus
