MessengerBee (Messenger plugin for MusicBee)
This is a simple plugin for MusicBee which will show your currently playing song in Messenger.
To install, download and run the self-extracting executable, choose to extract the files to the MusicBee plugin folder, and then restart MusicBee if it was running.
If MusicBee is installed in another folder other than what’s shown, please change the path before extracting.
You can check that MessengerBee is active by going into MusicBee’s preferences, choose the Plugins category and look for MessengerBee listed there.
thanks star TReKiE[2]
Pretty neat!!
…now can we get something like this for foobar2000? :stuck_out_tongue:
in the end, it depends on the API
(expecting a edge song reference, didn’t ya?)
@leeadelinelf make sure you have Turn on ‘what I’m listening to’ in messenger. here is a screenshot of it.
Good work, you should put your plugin here → Plugins for MusicBee
Thanks :slight_smile: I will consider it. When I made this a while ago I had reservations adding it to the site because Steven (MusicBee author) had recently removed MusicBee’s built-in Messenger support (since he considered Messenger “shut down”) and I assumed it would be rejected.
MusicBee looks cool and quite useful. I’d use it, but i don’t install movies or music on my gaming pc to optimize it for space and what not, i’d get it on my mac, but there isn’t any support (from what i saw on their website). Overall good job on making the plugin! :+1:
I don’t see my song, the song I was playing is in YouTube even T turn on show what I’m listening to.
It only works with a music app called music Ee not YouTube
