when i wanted to install on Messenger reviver 2. i got officially error message. Messenger was not installed either due to a connectivity problem, a problem in your installation or your manually cancelled the setup program. can anyone fix this messenger reviver 2? please solve this problem. i tired and i went to install that.
Reviver 2 used the files direct from Microsoft, which are no longer available. What are you trying to do? Here’s a link to the full 2012 installer if you need it.
