Hello,
I am trying to install messenger plus with messenger reviver.
It installs fine but it’s not working.
It worked fine with windows 8.1 in the same computer, but I didn’t like it so I reverted to Windows 7 and with that operative system seems to have problems.
I heard it’s NVIDIA graphics causing this, but is there a fix for it?
Thank you.
Does your notebook use an Nvidia video chipset? The latest drivers from Nvidia are known to break Messenger Plus!. In some cases if it’s possible, you can download to older versions of the driver to fix the problem.
EM PORTUGUÊS
Olá,
Eu achei a solução do problema, maaaaaaaaaas é muito chata de fazer --’
- Vá para o Menu Iniciar e digite: devmgmt.msc
- Selecione Adaptadores de Vídeo
- Clique com o botão direito do mouse no “NVIDIA” e “Desativar”, confirme a ação
- Abra o Windows Live
- Desfaça a epata 3 para reativar o Driver
Você precisará fazer isso toda vez antes de abrir o WLM, infelizmente
IN ENGLISH
Hi,
I found a resolution for this problem, buuuuuuuuuuuuuuuuut it’s a very boring to make --’
- Goto Start Menu and type text: devmgmt.msc
- Select Display Adapters
- Click with right buttom mouse in “NVIDIA” and select “Disable”, confirm action
- Open Windows Live
- Undo step 3 to will reactive Driver
Everytime before open WLM you need make this, unfortunally
