Hello, i’ve been getting this problem since earlier today after i turned on my pc from suspended state, messenger does not open from any shortcut. im suspecting i may need to get new shortcuts 'Cause after i moved most of my files to another folder is when the problem started happening.
Any toughts?
Go where Messenger is installed, create a shortcut for “msnmsgr.exe” and you’re done.
If it does not work, reinstall it.
