Hi, I tried to install this several times, and now I’m looking for help.
It was installing the messenger on this window, everything was fine:
Then after, this showed up:
And an entire list of logs that I don’t understand anything. I really doubt it was my connectivity problem, cause I tried different ones. I have Windows 7 Ultimate 64bits.
Pleeease, I love the messenger :(( I miss it so much. I tried every possible way.
As a first step, uncheck ‘Hide installation wizard’ and go through the installer that way - it will provide more clues without having to dig through the logs themselves.
If none of that works, e-mail me the details of the results of the above solutions and the last installation log in the folder Reviver opens for you at installlogs@jonathankay.com and I’ll take a look.
0 captured
0 currently
Capture the ghosts of messaging!
Hover, tap, or click the ghosts
(they can appear anywhere, but don't worry, they're friendly!)
