I need an english version and i caNT FIND IT HELP ME
Its saying 4.7.2009 i need 4.7.0105
Maybe i will download version 4.5 will it work?
The MSN Messenger Clients Archive probably has the version you need.
I am asking will 4.5 work
Yes. But, didnât you wanted to use version 4.7?
I compared both versions and its the same desingn so
Do i need to make a account in escargot msn server website with microsoft account yes?
Yup, you need to register on the page with an e-mail account (anyone is gonna be okay, it doesnât need to exist, but better if it exists if you forget your password) and a password. If you pretend to use versions 1 to 4 you need to enable the checkbox that says âOld MSN Supportâ. And thatâs it! Now enter your login data into the program and start enjoying MSN!
I now fix everyting and now i am enjoying MSN messenger
Good.
thanks. 4.6 signed on first try
i also found the right 4.7 download
i even got 2009 to work
Umm how ?
4.7.2009.
oh i thought he meant WLM 2009
i used the autopatcher
than did the patch in regedit
