Login in with the correct login details doesn’t seem to work in Mercury Messenger.
MSNP11: endless connecting…
MSNP15: Login-details/Password Wrong…
MSNP21: Login-details/Password Wrong…
is there someway to fix it?
OFFTOPIC:
Old Message
hopefully it’s in the correct section of the forum, if not please move it to the correct then.
Thanks for moving.
I have the same problem. after clearing cache, uninstalling / installing the application the fault continues
moved to the right section
msnp11: not working for some reason
msnp15: check if your password and email is right
msnp21: not supported by escargot yet
I pretty sure these are correct because I even reset my password tested it in WLM on my computer.
EDIT:
@EpicTaco404 I just reset my password again and it still doesn’t work…
I use MSN Protocol v15.
Possibly unrelated thing but I can log in, but I cant send messages to anyone.
msnp21 does that, it logs in but you cant send messages and (i think) presence
