I am gonna give a trashed laptop a new life!
Not as a laptop, but as a sorta-console!
It’s gonna run a modified version of the Windows Operating System.
I built this CLI Controller from scratch, specifically for this project. It will even know if it crashes!
And yes, this will run in Explorer’s place on startup, have tested it, and it all works!
Just to clarify, this Modified version of Windows will only stay until something like Lakka is stable enough for the machine.
Neat ![]()
Are you using the keyboard as the gaming controller or do you have something else in mind?
I’ll be using an actual controller, but will have a keyboard at hand in the event I need to input text, or navigate explorer or something.
SOMEWERE FOR YOU TO GET YOUR GAMES IF YOU NEED IT
