Making a proper skype revival from 5-8 (or only 5-6)
Hey Guys and Skype Lovers
im making a revival of skype 5-6-7 (not a clone) but an actual hex patching guide
its still in pre-alpha and not ready yet untill the release (i will try to make it before 2027) althouh im starting with it now.if anyone wants to help me. dm me on discord and you will be a contributor
We will have Full voIP support
and MSNP21 Support
and even support wlm 2011 and 2010 (yes 2010 existed) and 2012
MIND its still pre alpha. so dont ask for patching guides
ill also make a discord server once its in alpha
here are all the supported platforms coming:
Skype 5-6-7 And Windows Live Messenger 2011 2010 and 2012
Planned Skype Lite Support after june of 2026
Skype 0.96 support
Mostly everything with Skype Including Skype TX
Very maybeeeee oscar support (ICQ and AIM)
and the name issssssssssssssss
ARTAK
Gonna make an update if its alpha
Warm regards from khurrics
i have early patching guides for later.
up is what it used to be. down is what it has to be edited
ui.skype.com login.skype.com apps.skype.com static.skypeassets.com api.skype.com db.skype.com pipe.skype.com
ui.artak.xyz login.artak.xyz apps.artak.xyz (static not availible yet) api.artak.xyz db.artak.xyz pipe.artak.xyz
DONT TRY IT YET
Good luck on Skype versions support that uses the P2P protocol
Skype is entirely difficult to reverse engineer, especially the P2P ones. Sure, Skype 8 is easy because it uses Electron.
Guys, Skype somewhat still works through a Microsoft account. Just get Skype Lite and log in, Very simple, actually logs you in
yes, i know that
Well great it still… works?
does your skype revive work
Half yea, it lets you login, but no calling and you need skype lite for Android
Hey! Is ARTAK in alpha now? It has been 4 months..
can i use it now? again, it has been 4 months
well.. were really just still experementing the client.. skype is hard + my phone is reseted
oh.
