read title, i need help i tryed everything.
WiFi Reciever model please?
At least which Lubuntu release? Newest?
i supouse that Modelo Receptor WiFi is Realtek
and Lubuntu 18.04 LTS
Realtek… what exact model?
i will see, but how i see The network card in Lubuntu, i’m use more windows
you still here
yes
Try with other distros… for ex. Linux Mint
I don’t own any computer with Realtek as a WiFi card.
i want one for old Netbook
what
i want one distro for old Netbooks
Just stay with the distro you’ve got
Wi-Fi not Works
we already know that
Open a terminal with Ctrl + Alt + T and type sudo dmidecode | grep -A3 '^System Information' > sysinfo.txt, enter your password (the password won’t be visible as you type it in, keep calm; just type it and press enter) and copy that .txt file (which is in your home (~) folder) into a USB drive, then send it to us in this thread
i know
what archive
with that command, you’re creating a .txt file named “sysinfo” in your home folder. If you don’t know what your home folder is, them go to your file manager and go to, for example, the Documents folder. Then press the “one directory up” button and search for the file sysinfo.txt
