Hello! I’m currently stuck on this issue:
Let’s say someone hits you up on Messenger. You receive the RNG command and start a new Switchboard connection.
However, once you idle for a bit, you or the other person will disconnect, sending the BYE command. But then, if they want to talk to you again, they’ll send you another RNG.
Right now, I have a switchboardSessions variable which is an object (map) that holds another object with the key being the Switchboard session ID. I also have the Switchboard gateway session ID (because I’m using the HTTP gateway). Example:
add to switchboardSessions...:
parts[1]: {
gatewayId: gatewaySessionId,
sessionId: parts[1],
server: parts[2],
authKey: parts[4],
email: parts[5],
nick: parts[6]
I also have a messages object, which uses the Switchboard session ID (not gateway). Example:
messages: {
sessionId: [
text: 'HI',
time: new Date()
The issue would be when they talk to you, the session ID is different. How should I tackle managing this? That is, how would I know what switchboard session was the original?
Another issue would be group conversations…
Note: this is MSNP8.
