It’s almost one year ago since I was looking for the Window Live Messenger - 10th anniversary pack.
At the end, I was able to find it!
Here is the download link again:
Note!
You will able to install the pack to your Windows Live Messenger client using a third party program.
You should find and use a reliable one only as some third party programs can be a trojan. If you already have one, please share it here!
Another important thing that I was not able to receive emails from the email system in here.
Luckily, somehow I was able to regain access to my registered user…
I would like to announce that I found a lot of packages for MSN Messenger/Windows Live Messenger and I would like to share everything here with you!
You can find a lot of packages including emoticons, winks, backgrounds, dynamic display pictures and more of various subjects: Anniversaries, Holidays, MSN Buddies and more!
These packages are available at www.quebles.com and you will able to find a lot there.
You will able to download the packages directly from quebles.com using the following url:
quebles.com/content/[PackNum]/[PackNum].mct
Replace the [PackNum] with the number of the package.
For example: 125320 for Summer Cocktail package.
You will have to replace each file extension from .mct to .cab to view the contents inside.
I have decided to add here an attached file which is additional source for tons of packages and some of these are included in the file here:
MSNPackList.dll (3.2 KB)
Please open using notepad or replace the extension from .dll to .txt.
Please note that there are a lot of packages which may be copyrighted, so please use these personally only!
Thank you and I hope this makes you happy!!
