yes i tried that and it was just spinning.
ill try again tomorrow
what da client you use tho.
hi, i am using 2003b,
its working now so not sure what was going on, but ill get my details updated etc which is awesome!
i wonder if we can add back the old add-ins, like icq chat, and that email notification integration
either way this is so good to see!!
I also have the same problem!
ik how to fix
he used a qip 2005 build that isnt supported
SULOTION: use an older build of QIP 2005
Btw you can even use QIP Infinum Betas with KICQ
lmao like from most early build works and up to laters
but i heared in murb.com, there is a rare software that may patch QIP’s bug.
yes, you are connecting to a different (unofficial) ICQ server, so your old contacts etc will not come across.
there are ways to re add contacts from a device with the defunct icq but its not a proper transfer.
no its because my account is very new.
does this work on icq 99b?
