I want to use the school computer, but is it possible to use MSN without creating an account on the school computer?
simple answer: No
School PCs/Laptops are tired down and will have stuff like this blocked
depends on what computer
if its a chromebook, near impossible… but i do know an exploit for some chromebooks which allows for custom applications
dont need to with android side of chromeOS
from what i seen, that could also be locked down
it could work though? if it wasn’t locked down?
you cant just “turn that off”
i said locked down, not “turned off”
yeah most of the stuff is turned off not locked down
i guess so
yeah ive messed around with chromeos ages ago! hence why i know the android subsystem would still be kicking around!
