title says all
Yes its possible.
how?
It should be the same procedure as the installation on linux.
try to get the messenger for mac then patch with sublime text (i will try to patch in windows with it bc it like notepad++) the link of messenger and sublime is here https://download.sublimetext.com/Sublime%20Text%20Build%203200.dmg and
Thank you for downloading Microsoft Messenger from CNET Download.com
why cnet WHY
patching messenger for mac is not possible at this point as it uses another protocol
iirc xmpp
beacuse i only found on cnet
when i get a new laptop i will try (plz dont drama)
im telling you, its not possible as it uses XMPP, not MSNP, and the mac users in messengergeek are too low in volume to possibly have someone up for testing and helping to patch, unless im wrong
Run it with wine
i tried already but you cant
then y did u install mac os in the first place
And
(that was a may 2017 posts
