I know this isn’t messengergeek related but does anyone have a folder i can download with all the windows vista internet tray icons?
Update: i installed a copy of Vista but i can’t find out where the icons are stored. if anyone knows comment the file name of the .dll or .exe
Are you looking to change the icons of your current network connection icons? Or are you just trying to rip the Vista network connection icons.
i want to change them but i already have a tool for that so all i have to do is rip them
There’s a program called NetAnimate that will do that for you, it has a dropdown menu where you can select what Internet Connection Icon set you want from which OS, if I remember correctly.
