Hi guys…I don’t know how to set up to connect online?
or ICQ 7.8 not supported? Thank you
What ICQ Revival are you using to try to connect?
Probably KICQ, I think?
For me kicq highest version is 6
linkless:
the image who wants to change the settings but dosent know:
he is possibly using “ye olde ICQ”
Thanks…I wanted to run ICQ 7.8 and I guess the settings don’t work huh? Someone wrote to me that it only supports up to ICQ 6…It is true? Has anyone tried running ICQ 7.8?
yes. KICQ supports 99 to 6. but not only version 6. i managed to run 6.5 in KICQ servers so its supported
not only it supports the windows version
it can work with QIP 2005. icq 3.2/4 for mac OS (i found it), and more
for some reason. someone tried kicq servers in ICQ 7. but it most likely unsupported at this time.
Thank you for the information…ICQ 5.1 + 7.8 my favorite…I am sad that ICQ 7.8 is not supported :-/
Also too bad you can’t play RPS online or Sheep war
It can be played online
ZOOPALOOLA
too bad. KICQ dosent have a patch of games since it only has theese features:
We’ll file transfer DOES WORK but they need to be on the same ver
