So yeah i created a language ! I called this language Enguena ! Anyways there is the translated window
I taked my main language (French) for the base and then i translated words and tada ! As you can see its not complete but its still in work !
Have a great night/day !
For a exemple, if someone add you it will said
example@exemple.com cuenca o aguente ka luista de cuentacts
Which means
exemple@exemple.com added you in his contact list
How can a person learn to speak Enguena exactly?
Oh hi TReKiE ! Well, there is a txt file with words in english or french translated to Enguena here is a example with the french one
Which the txt files are not finished
And maybe i will make a sort of traductor for Enguena
nice!
Thank youu !
Cool, I have never seen a person from modern day create an language, i had ideas to create one but i was trying to make words and vocals and everything and stuff and thats rough
Thank you so much !
