i can’t use audio/video calling on Versions from 4.5 to 5.1, they have a start audio and start camera in instant messenger and it always doesn’t Work! Can someone Help Me Please?!.
i am using 5.0 and it does not Work?!.
That’s because… It simply doesn’t work! OFC It will fail! That feature is not yet implemented!
oh! i will put pic of problem
“from 5.0”
it has done this from versions, 4.5 to 5.1! do you know how to fix? have done sum Research
Orrrr maybe the old Audio Tuning Wizard on windows might be gone.
it does’nt work on 5.0 too
again, old Audio Tuning Wizard is gone, no more, Only on older windows versions.
oh…
what versions support audio and video conversationssssssssssssss
I don’t think any version of MSN/WLM support audio and video calls, but you can expect support for it to get added between 2026 and 2027.
also why Can’t i Download Windows Live Messenger 8.0.0290, it always says “Side By Side Configuration” Like And it has an Error, i will reply With the ERROR Code In 1 Minute.
wait 4 minutes
