So everytime i try to sign into escargot with my correct credentials it says its not right, even though im also using the patched version. Then i try my “same” credentials on nina and it works (obviously i had to use screenname instead of email for nina) but it worked for nina! So, does anybody know this error and anyway to fix it?
what windows version are you on, and are you using WLM 2009 (Escargot)
windows 11 and im using the recommended version which i think is wlm 2009
I see,
Its due to a bug in Windows 11 24H2 and above that prevents WLM 2009 from signing in, try this patch: https://static.nina.chat/distro/EscargotWin24H2.zip
thank you broski
uhh it gave another error 8e5e04b6
