I solved it removing some HOSTS ips: Due to windows don’t regconize
plz?
Because you’re in windows 10, WLM 8.5 should be working. ![]()
So…
- Win + r, type inetcpl.cpl, press enter.
- Click advanced tab
- Scroll down and make sure SSL 2, and 3 are unchecked, and TLS 1.0, 1.1, and 1.2 are checked.
Yes It is so, I click to reset to a default advanced settings
And even this, that problem continues
is your password more than 8 characters?
Yes, it is 9
I think thats a problem, I dont think certain versions support more than 8 characters.
sometimes clients wont sign in if your password has more than 8 characters, so shorten it to 8 characters or less and try signing in again
In this case you should try login like 10-20 times.
Same thingon another account
Nope, don’t works
not well…
Is it getting again the same error
I’ve got the same problem sometimes… But all I can say is… That what I do, is to close the WLM Messenger and then wait 5 minutes, and the I open It and voila! It works… Of course, that solution IS ridiculous… But It actually worked for me.
81000306 means the server is offline, or congested
