I have an idea
We need Escargot for Windows Phone 7 Messages app cuz it had before WLM on that app and Mercury for Android doesnt work properly.
Older versions of the Windows Mobile WLM is easier to patch, like using a registry tool to patch it to Escargot’s servers. I forgot the registry tool’s name, but it works as a regedit for Windows Phone.
please contact me if you remember it. i main a WM 6.1 phone and wanna try it.
can’t you just get a .exe file for wlm on windows mobile 6.1 (I think it can run exe’s) and patch with the escargot patcher or switcher? I rlly want to use wlm on windows mobile too
hoghly doubt this would work. it might rely on x86 or full-fledged windows APIs WM might not have.
Detours does not work with the CE kernel. Only the NT kernel.
I FOUND THE .EXE FILE I REPEAT I FOUND THE .EXE FILE for wlm for windows mobile 6.1, idk how to upload it here tho
You’ll need to do manual binary patching if you’re to patch it. Even then, YMMV because of WM 6.1’s lackluster (by modern standards) SSL support/expired root certificates.
